Home › Forum › Ask A Member › Finally found Grandfather’s Evinrude
- This topic has 23 replies, 12 voices, and was last updated 12 months ago by
JACQUES.
November 4, 2025 at 10:00 pm #301206
Wow, nice find, DB! I bet this motor is going to double it’s running time in the coming year. : )
November 5, 2025 at 10:40 am #301219Nice find! Few look that good! While you have the flywheel off, change the condensers. They go bad over time whether used or not. You may want to polish up the points with #400 sandpaper or stiff carboard. They have a high silver content and that can tarnish, which is like a coating of insulation on them. You can polish them up without removing them. Gap should be .020″ when max open.
Use at least 24 to 1 gas/oil mix. Some people use 16 to 1. I use 20 to 1 because it’s easy to dump a quart of oil into a 5 gallon can of gas and top off the motor’s tank from that. I use that 20 to 1 mix in 16 to 1 and 24 to 1 motors.
November 5, 2025 at 12:22 pm #301236November 5, 2025 at 3:15 pm #301242David, that’s an incredible find… if you need any pressure tanks, I have an extra in the Evinrude flavor. Good luck with it… would look nice on that yellow boat of yours.
1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
1955 Feather Craft Vagabond - 1956 Mercury Mark 55ENovember 5, 2025 at 3:49 pm #301246Tubs,
Nothing I like better than seeing coils like this!
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
November 5, 2025 at 3:53 pm #301247Today I cleaned the carb and stripped the magneto while waiting for new coils and condensers. I have a supply of NOS points, so I polished some and installed them and put the “old” ones in my spare parts pile. Will put the coils in when the Brown Truck shows up!
I put my initials on the welch plug on the carb because I do good work!
David Bartlett
November 5, 2025 at 3:56 pm #301251Wow, nice find, DB! I bet this motor is going to double it’s running time in the coming year. : )
David,
I’m sure I can add to it’s hours! It was right up the road from me too!
David Bartlett
November 5, 2025 at 3:57 pm #301252David, that’s an incredible find… if you need any pressure tanks, I have an extra in the Evinrude flavor. Good luck with it… would look nice on that yellow boat of yours.
Aidan,
I’m looking forward to running it. Thanks for the pressure tank offer, but I have 3 or 4 already so should be good to go!
David Bartlett
November 5, 2025 at 10:59 pm #301266Nice find!
I can’t help but wonder whether or not it was even run long enough to complete the break in procedure… Just in case, might be a good idea to give it extra oil for the next few hours of run time and keep varying the rpm to help preserve it as best as possible.👍
November 6, 2025 at 10:39 am #301275Congrats! It’s a gem!
It is particularly hard to find nice originals from the ‘58 evinrude line! They were prone to fading very easily, but that paint color combo is my absolute favorite!
Enjoy!!
