Home › Forum › Ask A Member › few questions
  • #1572
    Doug Wilson
      I was given a Neptune 15B2 and 6hp Chrysler that have both been setting since the late 70s, both were well oiled when put up compression seems good. The float is stuck to the shaft on the Neptune any suggestions how to get it lose so I can re-coat it? also need a prop and prop nut for it.
      Also any suggestions on where to get parts for the Chrysler, going to rebuild the carb, fuel pump and replace impeller and probably points and condensers (eliminate all the problems before I go fishing with it.
      Doug
      Doug
      turned off?
      #16689
      JOHN D.
        Doug Penn may be able to help with the prop and other Neptune parts. Laings comes to mind on Chrysler parts. Or you can try a want ad on this site.
        #16690
        jpatti75
          As for the float stuck to the needle, I’d first just try spraying it out with carb cleaner, as it is probably just gummed up old fuel causing it to stick. If that doesn’t work, try filling the bowl with a 50/50 mixture of Pinesol and water and let it soak over night. That stuff works miracles cleaning up a gunked up carburetor.
          JP
          #16695
            If you can come up with the part numbers for the Chrysler parts you need, try your local Mercury dealer. Mercury Marine kept the Force name after buying out U S Marine/Bayliner who in turn had bought out Chrysler Outboard and changed the name to Force Outboard.
