Home › Forum › Ask A Member › FD-15 lower unit
  • #4432
    rjoynt
      Changing the seal on the driveshaft. There were two seals. First one was in normal, the top one put in upside down. The kit calls for one seal and the part list calls for one. Any reason why there were two? There is room for both. Baffled and confused. 1961 18 hp Johnson.
      #37683
        Well someone was probably just trying to use a dual seal set up like found on later model engines. The outer seal’s lip faces out, meant to keep water from being pulled inside the gearcase. The inner/lower seal’s lip faces down to keep gear lube from leaking out.
        #37684
        rjoynt
          Sounds reasonable. But the driveshaft now has a groove where the seal lip is. The lower unit passes the air pressure test of five pounds for 15 minutes but still seems to get water in it. I’m thinking that the next thing is to replace the driveshaft. Thoughts?
          #37685
          chas56x
            I am thinking speedy sleeve to cover the groove worn in the drive shaft.
            #37686
            rjoynt
              Not familiar with that. What is it?
              #37687
                Speedy Sleeve is a thin stainless steel sleeve that goes over the worn area. They aren’t cheap. Neither is a drive shaft. How about the shift rod seal? And of course there are other places too, like the spagetti seal, etc, etc. How bad is it leaking anyway? You might consider a few extra oil changes if we are talking drops.
                #37688
                rjoynt
                  Frank, thanks for the response. The other seals are good. Under pressure, the driveshaft seal did leak originally. I pulled the two seals that someone had put in. Evidently it must have leaked in the past. Time to figure out how much to put in it.
                  #37690
                  jerry-ahrens
                    Aggreed,If you haven’t already changed it, the shift rod seal [o ring] is most likely the culprit…. very common to leak on most 50’s and 60’s OMC outboards. Easy to change with the correct tools. When you have the lowerunit pressurized, try wiggling the shift shaft around a bit to see if it leaks while shifting in and out of gear.
                    #37692
                    beerman57
                      Did you shift it, wiggle shift shaft and drive shaft, turn drive shaft while doing the pressure test?
                      #37693
                      rjoynt
                        Yep, did all of the above. Replaced many of them, have a couple dozen o-rings in the parts drawer. OEM rings. I use the Stevens pump for pressure testing. I even have Frank’s special tool! Thanks once again Frank!!
