Home › Forum › Ask A Member › FD-11
  • #261532
    busterbo
      Hello new member here I am trying to find lower unit seal kit part number for my FD-11 18hp 1957 any info would be great thanks
      #261544
        contact  vintageoutboard.com folks … they  have kits
        #261545
          This might be the kit you need.
          https://www.vintageoutboard.com/products/22-30001-gear-case-seal-kit
          #261547
            Yes, measure the OD of the prop shaft seal. There were a couple of different diameters over the years. Sometimes, in the long time these motors have been kicking around, the gear sets get swapped, along with the aft bearing carrier that holds the seal. Don’t just assume you have an OEM 1957 diameter seal, there.
            #261550
            busterbo
              I measured the prop shaft seal it 1 1/4” outside diameter thanks for all the help
