Home › Forum › Ask A Member › FD-11 prop nut question
  • #2661
    opposedtwin
      the parts catalog says the part number is #376501 but I have a NOS one that is labeled as fitting an FD-11 but the number on the box and on the nut itself is #305394. was the first number superceded?
      by the way, I bought some stainless rod at 3/16 and made a whole bunch of drive pins for the FD-11. thanks for the dimensions chris!
      thanks!
      scott
      EDIT!!!
      I just looked in a couple parts catalogs and see that the #305394 nut is for the 1958 QD-19 10 hp.
      ok, so does anybody have the right number for the FD-11 prop nut?
      #24805
        390716 is the newest number.
        Original part number of 376501
        http://www.marineengine.com/newparts/pa … OMC0390716
        #24813
        beerman57
          There is only like 2 prop shaft sizes, if the threads are right and the cotter key holes line up, you’re good.
          #24824
          opposedtwin
            Hmmm….. Nope. It’s too small. The 1958 shafts have smaller diameters. Dang! I’m not too excited about spending 29 bucks on one, that’s for sure.
            #24825
              Check with Doug Penn at http://penn.itgo.com/
              Or Dan Gano at http://www.ganotech.com/
              Steve A W
              #24827
              opposedtwin
                Oh yeah Steve! I have emails in to both those guys already.
                #24971
                opposedtwin
                  Does anybody know what motors would have a compatible prop nut that would fit the FD-11?
                  Also, anybody know when they started putting plastic prop nuts on instead of metal ones? I’d like to find a metal one if possible.
                  Thanks for any info!
                  Scott
                  #24973
                  wiscoboater
                    Scott, I have a 57 and a 59 parts motors. If you need one and it fits, it’s yours Buddy. Let me know.
                    As far as the metal to plastic goes, I have a 59 Evinrude 18 with the metal nut, but my 59 Johnson FD 13 has the plastic nut. So I’m thinking the change must have occurred around that time ❓
