Home › Forum › Ask A Member › Farting Evinrude
  • #14264
    david-bartlett
      If this motor has not been run in 20 years, likely it was run with older formulation oils which produced more carbon. Also, if you have put any Sea-Foam or like products through the fuel system, it will loosen things up.
      Not a big issue.
      #14271
        No, I wouldn’t worry about that. The plugs look like crap because the engine is farting/running lean. Once the air return line if fixed, put the engine on a boat so you can get the needles properly adjusted. Run the engine in gear at WOT so you can dial in the high speed, then slow it down so you can dial in the low speed. Make sure you have mixed the fuel at 16:1 for you initial run, just in case the engine is a little tight/rusted from sitting.
        #14286
          Please don’t rev it up high out of gear.
          #14295
          wiscoboater
            s
            #14318
              Good motor
