Home › Forum › Ask A Member › Fabricating Johnson A25 Muffler
  • #1933
      Any tips/tricks advice when doing this? I have an A 25 missing the sheet metal muffler, so plan on simply making one. Gauge of metal, and type required would be great to know.
      #19452
      steveh
        This site gives instructions:
        http://www.oddjobmotors.com/tt3_johnson … uffler.htm
        #19460
        lotec
          The Tech Tip on my site is only about how to make the inner muffler. I usually try Doug Penn when I need the outer muffler. Inless someting has changed, its one of those cases where buying one is a lot cheaper than making one!
          #19461
            That is great thanks.
            The outer muffler I should be able to easily fabricate as well out of sheet metal and rivets. Was it brass?
            #19463
            wedgie
              The one I have is copper I think. I will have a look when I get home
              #19464
              bobprock4200
                Look for a section of copper downspout if you can find it. It may or may not be the right dimension, but you can always make it smaller. Anything copper right now is crazy expensive though.
                #19465
                  Ok thanks. I do sheet metal fabrication, so will try some 0.50 copper sheeting and fab one up, and fab up a new inner piece as well. Will see how it goes. Probably easier than polishing and getting the dents out of an old one!
                  #19467
                    quote Bob Prock:
                    No kidding!
                    Believe it or not, Hong Kong or China is the cheapest spot to get the flat stock that I know of, with free shipping. You can get enough to do a muffler for likely under 10 bucks. Buy a few blind copper rivets and away you go. That’s my plan anyways, Ill post some pics of how it looks when Im done.
                    #19470
                    Goman
                      Dennis Trevathan makes them and other parts for the A models. Nice stuff.
                      dtrev@comcast.net
