Home › Forum › Ask A Member › Evinrude Zephyr Primer Pump
- This topic has 5 replies, 6 voices, and was last updated 1 year, 5 months ago by
George Emmanuel.
May 2, 2025 at 12:59 pm #296058
I cleaned the carb to an Evinrude Zephyr 4404 and upon testing it out again, I found that the little plunger assembly is not pumping into the primer tank. I took it apart and found the rubber to be hardened and shrunk, not properly contacting the sides of the pump to create suction or pressure. I know that the pump is getting gas into it, but not pumping any gas out. Is there anywhere I can find new rubber parts for the primer pump?
May 2, 2025 at 3:31 pm #296059Ken Hall might have the primer cups. I know he has waterpump impellers for the Zephyr’s.
May 3, 2025 at 9:09 am #296084I have the same issue.
May 6, 2025 at 10:34 pm #296245A few years ago I posted a fix for this very problem using readily available pieces similar to brake cylinder cups. I do remember posting part numbers and photos of the installation process as I had to shorten the plunger shaft a bit to accept the new piece.
I should still have the photos but they will be hiding somewhere amongst the 8K+ pics I have stored in my PC. Doing a Google search might find the post.
May 7, 2025 at 8:51 am #296248https://www.aomci.org/forums/topic/working-on-my-first-zephyr/
That might be the post Mumbles is talking about. Mumbles has GREAT pictures; it’s always a great day when I can find the ones I remember him posting a while back…….
June 3, 2025 at 10:44 am #296997Mumbles, I thank you! Edwin is my grandson and also a Jr. member thanks to grandaddy’s gift of a membership. As a follow-up, Edwin sent me the link to your post and I ordered the cups. This past weekend the family was here for graduation and Edwin and I did the machine work and installed the cup. The cup did make a difference but not completely. As it turns out, there is an additional “cup’ that acts like a check valve, and we tried the installation of one of the new cups and now have a very good primer! My son in law texted me yesterday after they arrived home and said Edwin made a beeline to his little workshop, and this morning Edwin sent me a video, —-it is now running!
Everyone on this website responds kindly and I appreciate that. You never know who you are responding to, and in this case, it is a 14 year old youngster who has fallen in love with the hobby. The encouragement and help provided by the respondents boosts the ambition and gives us new ideas to try. I have a 1935 Sport Four that is a sweet runner, but if the primer doesn’t work, it is a bear to start. I now have a possible solution provided I can find the proper size cup.
George Emmanuel
