Home › Forum › Ask A Member › Evinrude Zephyr carb
  • #6187
    mercuryman
      Carburetor #275787 (primer on carb knob) fit a Zephyr or Lightfour , Thanks
      #51703
      wyo307
        I’m confused. Are you looking for one or have a question about one? Either way I should be able to help out if you clarify.
        #51704
        mercuryman
          I am looking at one, part # 275787 fits what motor?
          #51706
          wyo307
            I think that carb is one of the ones for the navy version of the lightfour models 4375, 4376, and 4377 of the 1943 vintage. Those motors came with a "rebuild kit" which was a box full of spare parts which included this 275787 carb. That is also why most of them you find are stamped with the US bureau of ships stamp as well. This also explains why there are so many NOS ones around. If you look closely at the photos in the link below you can see one of the boxes in the rebuild kit has the 275787 cab stamped on it. Hope this helps.
            http://www.ahlstrandmarine.com/products … -1943.html
            #51707
            mercuryman
              Thanks
              #51775
                The Big four primer cup is 201144, the Lightfour primer cup is 201764, the Sportwin primer cup is 202119 – I don’t have a parts list on the Johnson QD12 which has a primer. . . 🙄
