Home › Forum › Ask A Member › Evinrude Zephyr 4404 questions
  • #2680
    genia
      Hi all,
      I am working on an Evinrude 4404 Zephyr, circa 1948. I was wondering if anyone knew where I can get the primer cups for this model (they appear to be identical) or at least a part number. Any diagrams would be appreciated IMMENSELY!
      Also, does anyone know what I should set the points to — will 0.020" do it?
      Thanks in advance!
      #24982
      wedgie
        Welcome Genia. 🙂
        Here’s a link to get yo started.I’ll try to dig up some more info for you.
        http://boatinfo.no/lib/evinrude/manuals … r.html#/10
        Try Doug Penn for the primer cups. http://penn.itgo.com/
        #25005
        kevinf
          A member did some research a while back to come up with replacement primer cups. This might help:
          viewtopic.php?f=2&t=1513&p=8087&hilit=primer#p8087
          #25007
          Leon
            I believe .020 is correct for the points
            #26638
            genia
              Thanks everyone! Super helpful and a great start. The 1949 isn’t all that different — just the lower unit and a couple minor things. Thanks for getting me moving!
