Home › Forum › Ask A Member › Evinrude transom clamp screw pad
  • #303652
    Tfelty
      Is there a trick to removing the pads off an old Evinrude RBM transom clamp screw? I need to replace a broken one but don’t want to break the ears off snapping it on/off. Any guidance is appreciated.
      #303655
      RICHARD A. WHITE
        Yes…. place an open end wrench, about 3/4 should do, between the pad and the transom bracket. Then back the transom screw out and it will “pop” off of the screw.
        classicomctools@gmail.com
        #303656
          then…
          https://www.youtube.com/shorts/-K4zAeh_GWo?feature=share
