Home › Forum › Ask A Member › Evinrude Sportwin 4421
  • #5767
    ray-mason
      Gentlemen,
      I found this Evinrude 4421 Sportwin at an antique fair last weekend. It’s complete minus the recoil mechanism and knobs, has compression (haven’t measured it yet), and I haven’t checked for spark yet. Overall it looks like it’s in pretty good shape. I see some discussion on the later 4423 and 4424 motors but nothing on the 4421. Does anyone have any info on this motor?
      Thanks,
      Ray in Brandon, FL
        What you have is a ’47 3.3 horse opposed twin motor. The ’48 and later 4423 Sportwins were inline alternate firing motors. It originally called for 1/3 pint of oil per gallon (24:1) but it might be better to use a bit more oil. 1/2 pint per gallon would make a 16:1 mix. It spins a 7 X 5.5 inch two blade aluminum prop with a 3/16 X 27/32 hard brass shear pin. The plugs are gapped at 0.025 and the points at 0.020. The 171449 condenser/capacitor should read 0.010 uF (mfd) with an allowable +/- 0.02 uF.
        Here’s some more info on your 4421.
        ray-mason
          Thanks for the information Mumbles, that helps a lot!
