Home › Forum › Ask A Member › Evinrude speedifour coils #7031
  • #11221
    oldboatmotors
      Wondering if I have any options as far as replacing these coils. Or are they repairable? The spark plug wires fell off one and the smaller wires are brittle.
      david-bartlett
        Gus,
        Welcome! That coil doesn’t look good. Lots of folks have substituted other coils on lots of motors.
        Here is one thread, others will likely follow. Not exactly what you want, but the same ideas apply.
        viewtopic.php?f=2&t=17342
        #83036
        oldboatmotors
          Thanks, David. I’m considering trying different coil types. I’ve been searching here and not really finding info on doing it.
          #83038
          lyks2tinkr
            Before condemning the coil have you measured the secondary resistance?
            #83040
            TOM GOEPFRICH
              Wires are not that hard to replace if the coil itself is good. Did you test them?
              #83042
                /a>
                #83105
                oldboatmotors
                  The coil did test ok prior to my trying to solder the plug wires on. It quickly went down hill from there. Now I’m looking for another coil.
