Home › Forum › Ask A Member › Evinrude seal numbers
  • #3322
    JOSEPH BRINCAT
      Hi ya’ … anyone have info on Chicago Rawhide (or ?) part numbers to replace old Evinrude seal part numbers? The motor is 1951 25HP , prop shaft seal is 302564 and the drive shaft seal is 302545. Any help would be appreciated.
      Thanks,
      #29605
        I don’t have any P/N’s in front of me but try entering your P/N here at this SKF interchange site. It will give any current P/N’s available.
        http://www.skfextranet.com/Catalogs/457 … change.asp
        #29607
        ED
          p/n 302545 supersedes to 313284 p/n 302564 is still a good number. I have both
          #29612
            For the drive shaft, pn 302545 the skf number is 6904
            For the prop shaft, pn 302564, the skf number is 7533
            I carry the full seal kit if you need it all at myoldboatmotor.com for $22.45
            This includes the ds seal, ps seal, shift rod o ring, 2 nylon crush washers for drain/vent screws, o ring for prop shaft housing, upper drive shaft o ring, small o ring for shift rod Phillips screw, and of course the spaghetti seal.
            I am trying to figure out a way to add little tubes of 3M 847 to the kits as well, but currently that is not included.
            #29636
            JOSEPH BRINCAT
              Thanks guys, and that SKF exchange site looks to be very handy
              #29652
              JOSEPH BRINCAT
                Chris P , a question please … is the seal kit that you have from Chicago – General ? or some other seal supplier?
                Joe
                #29665
                  No my own supplier.
                  #29676
                  Leon
                    Chris_P are you formerly known as Hightrim?
                    #29689
                      Yes sir Zeph!
