Home › Forum › Ask A Member › Evinrude RBM questions
- This topic has 29 replies, 5 voices, and was last updated 9 years, 10 months ago by
Tubs.
December 8, 2016 at 4:10 pm #48855December 8, 2016 at 4:28 pm #48858December 8, 2016 at 4:36 pm #48859
NEVER give up!!!
classicomctools@gmail.comDecember 8, 2016 at 4:40 pm #48860December 8, 2016 at 4:54 pm #48862cast iron stand has aluminum head on it…… also will point out the guy standing behind the curtain has his buttocks pointing the wrong way…..
What Richard is pointing to is merely the extra bracket that is part of the tilt lock mechanism that was supplied on some Evinrude motors, I believe it was an accessory and not standard equipment. It added weight to the motor as well as elevated the powerhead slightly higher than normal. Also known to lock the motor so it could not tilt up, would also allow you to tilt the motor easily for beaching.
Hope this helps.
Best,
December 8, 2016 at 4:58 pm #48863Bill the brass piece is from a Cross Seagull model 582B, which is the very rare/never seen/not known to exist extra-long shaft salt water version…..
Or could be from a Johnson………. or evinrude……. or Lockwood …….or something else…..
Hope that helps.
Best,
December 8, 2016 at 5:08 pm #48864December 8, 2016 at 5:17 pm #48865The biggest challenge is fuel leakage when it’s tilted up – the previous owner has fitted a soldered up wingnutted vent screw to the fuel cap. I’ve thought of relocating the fuel cap to the rear of the tank where it belongs. I’ve held onto a battered tank to practice on and took a close look at it last night – I was amazed at the overlapping/interlocking folded seams – I had always assumed they were just lap joints that were soldered.
December 23, 2016 at 5:20 pm #49635quote bill_loveland:Tried to make a coil plate from a later RBM work on my 1914 last night – not a chance. The crankshaft’s an inch or so shorter and there’s just no way it could be modified to fit.Back to the drawing board.
It did give me the opportunity to take off the timer lever for the battery ignition setup – what a cute little piece of brass that is.
I made it work last night – fitted a 1915 (ish) mag plate under the 1914 flywheel! 😀
December 23, 2016 at 6:34 pm #49644.
