Home › Forum › Ask A Member › Evinrude points oiler wick
  • #41464
    fishbrick
      Thanks for the responses everyone. One other question, do you pre-oil the felt before install, and how does it continue to stay oiled?
      #41465
      amuller
        Is this better than greasing the cam?
        #41468
        fisherman6
          The wicks come pre-oiled with a very light oil so I would say pre-oiling it is the way to go. Do not over oil it or it will sling oil and foul the points. It holds enough oil to lubricate the points cam for quite a long time. It is recommended that the wick be replaced with regular tune ups. The wick will keep the points lubricated for that time. That said, I have cheated and lightly oiled the wick if it was still intact but dry. I used something like Hoppe’s gun oil or 3 in 1 oil and just enough to lightly dampen the wick.
          Use the wick to oil the cam. I would not grease the cam.
          -Ben
          OldJohnnyRude on YouTube
          #41472
            I also lay a little grease in the right angle of the points rubbing block wont throw the grease out just lubes as it wears.
            #41488
            fisherman6
              Agreed, if a dab of grease was placed inside the rubbing block, that would work OK. It would lube a bit as it wears and would not sling out.
              -Ben
              #41519
              fishbrick
                So do you think using a grease like a distributor grease is better than the oiler wick; or should it be used with it?
