Home › Forum › Ask A Member › Evinrude Parts
  • #4131
    joellerich
      I am looking for a source for parts for a 1955 Evinrude model 15014 Need head gasket and lower unit pinion gear.
      Thanks
      John
      #35501
      shoestringmariner
        Try these guys
        http://www.myoldboatmotor.com/motors-.html
        http://www.vintageoutboard.com/
        I’ve had dealings with both. Top shelf, both of them
        #35513
        Casey Lynn
          Try an authorized Evinrude dealer. Many will order it for you…..support your local business when you can.
          #35534
          rmhxruss
            The head gasket is P/N 203247. The pinion gear is part of a set P/N 375844.
            #35536
            Leon
              I have a complete gear set from the slightly later model. The case is shot, but the gears are good.
              #35588
              joellerich
                Thanks for all the info. Found a gear set locally this morning. Will try ordering head gasket
                John
