Home › Forum › Ask A Member › Evinrude opposed 4 cylinder
  • #4597
    klined9114
      I have a mod # 7031 ser # 12505 Evinrude opposed 4 cylinder engine. I think it is a 33.4 hp. Does anyone have any info on this engine. Original color? Possibly a picture of original decals.
      #39045
      RICHARD A. WHITE
        Gonna guess Spedifour….
        classicomctools@gmail.com
        #39046
          #39047
          klined9114
            Thanks for the photos . Any trick to free up cylinders? I have removed the powerhead but have not removed the cylinders yet. Have the crankcase and cylinders full of light oil. I will install grease fitting in head and try to pump full of grease to break pistons loose. Any suggestions?
            #39049
              Sent you a PM.
              Check your messages at
              the top of the page.
              #39097
              david-bartlett
                quote KlineD9114:
                1950 SpeediFour. 150lbs of fun on the right boat! Original color was silver on the steel and nothing on the aluminum. Only decal is on the tank.
                #39105
                  You don’t want to use the grease gun method unless the cylinders
                  are removed and the rods separated from the crank.
                  Otherwise if more than one piston is stuck it will force something you don’t want to.
                  Tubs has a lot of experience with these old timers, He’ll help you get it going.
                  Good Luck with your motor!
                  Steve A W
                  #39136
                  kees
                    International Member
                    Is the post war color " green / blue " decal more common ?
                    ( I couldn’t find a better picture, sorry . )
                    #39137
                      Please do not pump grease into it. Remove the cylinders & soak the assembly then listen to Tubs
