Home › Forum › Ask A Member › Evinrude Model R locking transom clamp
  • #329943
    Markle Stanberry
      I feel like it’s blasphemy, the thought I had of drilling it out. I suppose I could try to revive the lock picking skills of my youth but if the tumblers are as frozen as the rest of this little motor was there might not be any “feel good about it” option.
      Were the keys for these unique to each motor or did they use something similar to a modern riding mower’s “one fits all” keys?
      1967 Johnson 9.5 "Grandpa"
      1962 Sea King 3hp
      1957 "Monkey Ward's" Sea King 5hp
      1956 Gale Buccaneer 12hp
      1955 Evinrude Big Twin Electric
      1955 Goodyear Sea Bee 5hp
      1953 Evinrude Big Twin
      1947 Martin 40
      1927 Evinrude Model R
      #329947
      RICHARD A. WHITE
        Have you called a locksmith?
        classicomctools@gmail.com
        #329966
        PM T2
          The inner part of the lock is probably die-cast zinc. The zinc alloys of that era were very unstable due to tramp elements (aka contaminants) being allowed to build up in the molten zinc furnaces.  in most cases, the culprit is lead, as the standard created in the early 1930’s states that lead can only compose less than 0.003% of the alloy. In the late 1920’s, it is known that the alloys often contained lead contents of more than 1/2 of a percent, which leads to the breakdown most often seen in Tillotson carburetors in the 1927-29 era. The cracking you see is due to a phenomenon known as “intergranular corrosion” that causes the original casting to start to wander from its original form by growing or “creeping”. There isn’t likely a way to get that cylinder out without destroying it, but keep in mind its already basically destroyed, it just can’t show you how bad it really is. Tom Manley wrote an article in the Antique Outboarder that was printed in the January 1992 issue of how he dealt with a seized up lock cylinder and how he fixed it using modern parts to make the lock functional again. The number on the lock might correspond to a code that allows a locksmith to make a new key, but the innards are going to be jammed up so I doubt even the proper key would get the lock to work again.
          Hope this helps.
          Best,
          PM T2
          #329972
          Tom
            They can be rebuilt, I’ve done a few of them on N’s, R’s and T’s. Carefully drill out the cylinder, but don’t nick the nickel plated retaining ring. Break up what’s left and extract it. Plan on this taking a LOT of time. Then remove the ring which is just staked in place. There is a spring loaded rod at the back of the hole, which moves up and down as the cylinder was rotated with a key. You’ll need to remove the transom screw, and get the rod to drop out of the hole in the bottom of the transom clamp. Once that is all freed up, you’ll need to find a replacement cylinder and key. I’ve used cylinders from office furniture. You will need to shape the back of the cylinder with an offset circle to move the rod up and down. When all is fitted, replace the retaining ring.  See the crude diagram and an example of what the cylinder looks like.
