I found this in the ’54 shop manual. Doesn’t the float needle have little brass clips which slide down the needle to hold the float in place?
Also, here’s a manual for these carbs so you can take them apart without breaking anything. The Zephyr carb is basically the same as the Lightfour carb except for the bolt pattern.
ZephyrCarburetorMaintainance
This reply was modified 5 years, 11 months ago by
Mumbles.
Mumbles.
