Home › Forum › Ask A Member › evinrude identification
  • #1096
    mineola
      The following number is on my antique evinrude outboard:
      4425-18461 C
      Does this tell me the year and horse power?
      #13249
      ggoldy
        Yes
        ’48-’51
        1.5 horse
        #13251
        mineola
          Thanks Gary. I was given this motor and want to go through it. Do you have a favorite site that shows step by step info on this vintage?
          #13259
            In my opinion, one of the best singles ever built. Ball bearings in the lower unit require gear oil. The drive shaft seal is part number SKF-4770 and the prop shaft seal is SKF-5523. It runs on a 24 to1 mix of gas to oil. (⅓ of a pint of oil to each gallon of unleaded gasoline.) The Champion J6C spark plug is set at .030" – breaker points are set at .020". The fuel shut off lever also controls the air vent.
            #13272
            ggoldy
              Mineola, this place is great. Where else can you get information like that in 30 minutes?
              #13277
                ggoldy
                  Dang! Like ‘showroom fresh’!
                  Wait, I think I see some dirt in those screw slots 🙂
