Home › Forum › Ask A Member › Evinrude Fleetwin help
  • #1873
    CHUCK WEBSTER
      Does anyone have a detailed drawing of the water pump assembly for this motor, model 4443, neutral clutch? i need to see how the water inlet pieces are assembled. the impeller seems ok, but it won’t pump in the test barrel. Also what are initial carb settings for this motor. ( I am getting ready to sell.)
      Thanks,
      Chuck Webster
      Arlington, VT
      #19024
      Leon
        That is a Tillotson carb on that. Low speed is about 1/4 turn out and high speed is about 3/4
        The low speed needle on these is an air bypass, rather than a fuel flow (like the later Fleetwin carbs.} Evinrude used the Tillotson carbs on the Fastwin models through 1952 and 1953 on the Fleetwin.
        #19026
          This is a different model, but pump is the same: http://www.knology.net/~tombeam/images/partsmanual.pdf
          Can we assume you have the correct impeller? Hint: The pump sections are all keyed together and must be aligned correctly. The flat spring underneath holds it all together.
          #19032
          CHUCK WEBSTER
            Thanks that is very helpful.
            #19037
              4443 Fleetwin
              #19057
              CHUCK WEBSTER
                Thanks Garry, I think I have the plate in the wrong position. Will pull it apart and check.
                #19060
                  Garry’s picture shows the flat spring upside down. (Not Garry’s fault, he didn’t draw it).
