Home › Forum › Ask A Member › Evinrude fisherman 1956 pistons
  • #200958
      If the pistons are badly damaged and the block is still good, any piston from a ’54 5.5 up to a ’79 six horse can be used. The only difference is the number of rings on them.
      #202453
      aldenwhitney
        Update on the motor; After 3 weeks of soaking with transmission fluid, the pistons moved within a minute of trying to turn the fly wheel! Just ordered new gaskets and going to start to re-assemble the motor soon. Thanks for all the advice
        #202461
          OK, good to hear the first step is done. Keep us posted on future progress.
          1982 Evinrude 25hp
          #202467
            did you ever open up the cyl head to check cyl walls ?? if you remove the reeds maybe you can peek inside to look at the innards with a small camera…
            up to you but if innards don’t show rust I would close it up see if it runs a…..my 9.5 ran great with “freed up” stuck pistons
            • This reply was modified 6 years, 6 months ago by JACQUES.
