Home › Forum › Ask A Member › Evinrude Emblems. Can they be restored?
- This topic has 20 replies, 14 voices, and was last updated 4 years, 6 months ago by
Monte NZ.
July 2, 2019 at 10:33 am #178317
Working on a mid 50’s Evinrude 15020. These emblems are scratched, the paint is chipped, you know, normal wear and tear. Has anyone restored these? Are there any procedures to restore these documented or available? Does any one make repops of these?
Any help would be appreciated. Thank you
Bill
This topic was modified 7 years, 4 months ago by
Mumbles.
July 2, 2019 at 12:48 pm #178326North York Marine in Canada makes reproductions, but they’re not 3D: http://www.nymarine.ca/EVINRUDEmedallions.html
http://www.omc-boats.org
http://www.aerocraft-boats.orgJuly 2, 2019 at 1:19 pm #178328Those emblems are delicate for sure, I would not make any attempt to “restore” them….I would just reinstall them, provided they are not cracked/broken. Decent used ones do show up occasionally, but bring big money….You can post a classified ad here or look on ebay….
July 2, 2019 at 3:41 pm #178335There is currently a NOS emblem up for sale in the Classifieds section of the site.
This reply was modified 7 years, 4 months ago by
Bob Wight.
July 2, 2019 at 8:55 pm #178349I have tried painting the worn areas with nail polish before but wasn’t too pleased with the results. Model paint might work better.
July 3, 2019 at 8:17 am #178363I believe those are painted on the back side. I’ve touched similar ones up using spray paint and a fine brush with pretty good results. Pretty delicate work.
July 3, 2019 at 10:47 am #178366Thank you all for your responses. My first issues is getting the old paint off. I have paint stipper but am not sure that the stripper won’t melt/ruin the plastic.
July 4, 2019 at 6:55 am #178391Yes they can be restored with a very delicate touch.
The paint cannot be removed with anything that is too aggressive. It will craze the plastic which must stay smooth and clear. They are painted from behind , then a gray paint over the last color so it is opaque.
I use thin viscosity super glue to fill cracks and scratches. Build it up in layers then sand smooth going grit to grit through 1500 or greater wet dry sandpaper, then buff out with McGuire’s Polish…working from aggressive to fine usually by hand with a microfiber towel.
I use either testers enamel or sometimes a product for RC race cars that is Alclad Lacquer from the hobby store if the color is available. RC car bodied tend to be painted inside out like the emblems. Use an airbrush for this. The Lacquer or paint may be translucent when done, so that is where the gray back painting is important.
Hope this helps!
Greg
CHUCK.
July 4, 2019 at 10:20 am #178403Thank you Greg. That helps a lot. What do you use to remove the old paint?
July 4, 2019 at 11:03 am #178407 -
