Home › Forum › Ask A Member › Evinrude Emblem Attachment Hardware
- This topic has 8 replies, 5 voices, and was last updated 1 year, 5 months ago by
Motomanmatt.
May 25, 2025 at 6:41 pm #296768
Hi. A couple of questions.
1) I’m stripping and going to repaint my 57 Evinrude Big Twin cowling. The left and right side of the cowling have circular plastic Evinrude “E” emblems held onto the cowling by 3 small – since I don’t know what they’re called, let’s call them “gizmos” – that insert through the circular emblem and through the cowling (see photo). In the center of each little gizmo is a pin that, went inserted, spreads out the little arms of the Gizmo on the backside of the cowling, holding the emblem in place. When you remove the pin the little arms on the Gizmo retract enough that you can then pull them out and remove the emblem. Which I have done. I was very careful, but one of the gizmos arms got a little damaged. If I wanted to replace this Gizmo, I would do an internet search. But I don’t know what the Gizmo is called. Does anybody know the proper name for this little item?
2) One of the plastic circular E emblems has a bad crack. Is there any source for a replacement?
Thanks in advance for any help on these questions!
Matt
May 25, 2025 at 6:53 pm #296771visit NAPA they have all sort of these pin rivets… something must fit or… check AMAZON
May 26, 2025 at 6:37 am #296775The original medallion fasteners are still available at marineengine.com. MarineEngine.com
The medallions are very difficult to find NOS and are usually very expensive if you can even find one.
I have had very good results repairing and refinishing these medallions even when cracked in half as long as the medallion is complete.
Improvise-Adapt-Overcome
May 26, 2025 at 7:58 am #296776Thank you all! Appreciate the quick replies!
May 26, 2025 at 9:04 am #296777One more quick question: I’m going to attempt to restore this cowling to its original look. I’ve been cruising the internet looking for images of cowlings for the 35 HP Big Twin to use as an example for how mine should look when it’s done. I’ve yet to find one that looks like mine. My cowling has a chrome Evinrude script on it. See attached photo. I’ve not found a photo on the internet that has that. Thoughts?
May 26, 2025 at 10:45 am #2967791957 Evinrude Brochure
May 26, 2025 at 11:42 am #296783Your cowl may be the one with the “Electric Starting” badging. The “Electric Starting” 18 Hp has the same chromed “Evinrude” badge on the upper part of the cowl just like yours.
May 26, 2025 at 8:35 pm #296789I have one with an original hood. The electric start wire plug has been deleted for a pig tail hook up. The hood is correct. I was surprised it only weighs 130lbs. Feels like lots more.
dale
May 27, 2025 at 7:28 am #296793I have one with an original hood. The electric start wire plug has been deleted for a pig tail hook up. The hood is correct. I was surprised it only weighs 130lbs. Feels like lots more.
dale
Thank you!! Big help.
