Home › Forum › Ask A Member › Evinrude Elto Cub – Best Gas Tank Paint?
  • #328381
    Timothy Hertle
      What is the best brand and correct color paint for a 1939 Evinrude Elto Cub(paint gas tank)?  Want a high quality spray paint that is mixed gas resistant and durable as I am running my motor on a canoe.
      Motor runs great and pushes the canoe perfectly(around 5 mph).
      Painting only the steel gas tank to protect against rust.
      #328394
        I believe Dull Aluminum was the correct color.
        You might use DupliColor Cast Aluminum Engine Enamel
        (spray cans) which is a little duller than their plain “Aluminum”.
        It’s also gasoline resistant and heat resistant up to 500 degrees.
        If I’m putting decals on a tank, I usually use the Duplicolor
        Engine Clear over it.
        Glad you got that little putt-putt running good!
        bkrsdoz
          I like the Rustoleum Matte Nickel paint.
          Great for these, and Merc KG series legs.
