Home › Forum › Ask A Member › Evinrude CrankShaft Seal
  • #227470
    captainkidd
      I have a 1960 Evinrude Sportwin 10hp SN 10020 . I found only one oring in the lower crankshaft seal . The parts book shows 2 different rings for the lower seal. One oring goes in the carbon seal retainer however I am not sure where the second oring should go.
      Does anyone have any experience or information where the second oring should go or if it is even needed ?
      Thanks
      • This topic was modified 5 years, 10 months ago by captainkidd.
      #227471
      olcah
        Usually goes around the outside of the lower crankshaft bearing.
        #227472
          The parts book is misleading. Only one o-ring, inside the carbon seal. The other one they show goes around the lower main bearing, and is not an issue unless the crankcase is split.
