Home › Forum › Ask A Member › Evinrude compression
  • #5865
    harley-fixer
      I have 1957 Evinrude 5.5 fisherman. 75# compression on 1 cylinder. 0 on the other. What i looking for?
      #48915
      fisherman6
        The first thing I would check is if both pistons are moving. Pull the spark plugs out and have a look while you rotate the flywheel. If both pistons are moving and compression is 0 on one cylinder, it could be a blown or leaking head gasket. Check the head bolt torque. Loose head bolts could be making the head gasket leak. If it still checks out, remove the bypass cover on the suspect cylinder and have a look at the rings. That could be stuck or broken. Cylinder badly scored, etc. I would try those things first and report back with your findings. The 75psi on the one good cylinder is pretty good compression for a 5.5.
        -Ben
        OldJohnnyRude on YouTube
        #48919
          Agree with what Ben just wrote. But Zero compression, like none at all, pretty much indicates the piston isn’t moving or is broken. Or the head gasket is blown, not just leaking. No bypass covers on a 5.5. Stick a screwdriver in the spark plug hole to see if the piston is moving. If it is, off with the head for a looksee.
          #48923
          fisherman6
            Frank is right. No bypass covers on a 5.5. I forgot about that. 🙄
            I agree that 0 compression is most likely a piston that has freed itself from the crank somehow or has a piece missing. If the piston moves pull the cylinder head and have a look. Excellent advice Frank. 😉
            -Ben
            #48925
              Ben .. check your in box messages you are OK’d to access a file on dropbox
              #48927
                If it’s the bottom cylinder reading 0, it’s commonly caused by water getting in thru the lower seal causing the motor to throw a rod. That’s worse case scenario so hopefully it’s just a head gasket.
                #50063
                harley-fixer
                  It is the bottom cylinder that has 0 compression. Piston isn’t moving. Hope I can repair without spending a fortune.
                  #50081
                  fisherman6
                    If it’s just the rod or even the rod and piston, there are LOTS of parts out there. I have 3 5.5s with issues and I’m going to try to make 1 good one out of them. Parts motors are all over. You may also find a good powerhead for a reasonable price and just swap it out.
                    -Ben
                    #50110
                    david-bartlett
                      Bottom piston not moving is not good news. A used replacement power head is the way I would go. It will be cheaper and easier than repairing yours if it is even salvageable.
                      Put a want ad on the board. They made a ton of them and should be easy to find.
