Home › Forum › Ask A Member › Evinrude 9.5 powerhead isolation
- This topic has 11 replies, 4 voices, and was last updated 3 years ago by
frankr.
October 8, 2023 at 11:05 pm #281455
Hello all, I’m helping a friend with a 1969 Evindude 9.5 model 9922S, that is the motor with the low profile enclosure shroud. I see that the powerhead is rubber mounted for isolation but geez there seems like an excessive amount of free movement. I can move the powerhead about 3/4 ” fore and aft with in the shroud before I encounter hard stops. Does that seem right? My first-time encounter with this model, so I have no point of reference.
Thanks,
October 8, 2023 at 11:16 pm #281457I believe these motors are well known for their rubber mount failures.
I see yours has the vibration dampers as well as the rubber mounts.
I believe OMC added these dampers as the earlier models had
lots of “shaking” problems.I went through one in the past, and there should be a thread on it
in “Current Projects”, showing all the rubber mounts, etc.Prepare to be boarded!
October 8, 2023 at 11:42 pm #281459Thank Bucc, yes this has a sliding damper on the starboard side of the powerhead. I’ll look for your posting
October 9, 2023 at 12:12 am #281463my 9.5hp is at the cottage going from memory.. i think 3/4 inch movement is ok these turtles flop around
my 9622a does anyway but it works fine…but I did take it out and popped in a Merc 4hp…smoother and cheaper on fuel for trolling all day long
October 9, 2023 at 9:55 am #2814713/4 fore and aft is a broken upper front motor mount. l’ve replaced lots of them back in the day.
October 10, 2023 at 9:21 am #2815103/4 fore and aft is a broken upper front motor mount. l’ve replaced lots of them back in the day.
Thanks Frank. So now I have to figure out how to get to this motor mount. I suspect that I have to open up the entire “clam shell” housing. See what other complications that involves. My first time with the low profile motor, learning! Any info on a part number would be helpful.
October 10, 2023 at 11:06 am #281514Yep gotta shuck it out of the shell
I suppose marineengine has the parts list posted but haven’t looked
October 10, 2023 at 11:37 am #281516try utubes for tear down ..of the 9.5
October 10, 2023 at 11:40 am #281517previous reply got spoofed ???
2nd try…
ok i’ll have to check mine for 3/4 ply although I did not notice any problems. gotta hurry … winter is creeping in
October 10, 2023 at 12:05 pm #281518In case you didn’t find it, my thread on the subject motor……..
Bunches of photos showing the mounts, etc.https://www.aomci.org/forums/topic/evinrude-johnson-low-profile-9-5-hp-adventure/
