Home › Forum › Ask A Member › Evinrude 85 hp trim and tilt
  • #4586
    mgsolakis
      So let’s say I accidentally hooked up the trim and tilt on the motor wrong what would I fry? I just got a trim and tilt for this motor as it did not have one originally I hooked it up with 2 wires going to bottom terminal of the solenoid and one to the top, but now I think the 3rd was a ground or something. Because when I used the trim it was moving but the starter was turning as well. I stopped right away but when I put the 3rd wire to ground the trim was dead. The solenoid is still working because th motor turns over and I tried replacing the relays. What should I look at. Is it a ground wire? The model number is E85MLCSA.
      #38961
        OK, I’m lost, don’t understand what you are describing…
        How many wires does the trim motor have coming out of it, two or three?
        Three wire motor: The black lead is always grounded. The blue lead is connected to battery positive (green lead not connected to anything) to make the trim motor run in the "UP" mode. The green lead is connected to battery positive (blue lead not connected to anything) to make the trim motor run in the "down" mode (opposite direction).
        Two wire motor: Green lead is grounded and blue lead connected to battery positive to run the unit in the "up" mode. To run in down mode, blue lead is grounded and green lead is connected to battery positive.
        Both of these types of trim motors require separate trim/tilt junction box harness in 1980. The junction box/harness for the three lead motor is completely different (just one conventional solenoid) from the two lead motor junction box/harness which had two relays in the box.
        You can not connect either of these systems through the starter motor solenoid or you will be in trouble.
        Post pictures of what you have if that will help….
        #38973
        mgsolakis
          I don’t know how to post pictures on this site. It has a junction box but are there any fuses that I could burn out? I replaced both relays.
          #38974
            I believe the relays flip polarity is all. One for trim up/down & The other is for tilt up/down. You need to locate the correct pair, then reverse the pos/neg polarity. The motors are different too. The first motor is double wound for both directions & the later motor is single would, I believe. I have never been inside this set up but it is the logical way to wire a reversing motor. Later they learned with a DC motor it can be reversed inverting the inputs using direct current.
            #38981
            mgsolakis
              Jeff the system I have has only 2 relays in it. I was using it successfully on a 70 hp motor and it worked great. Then I switched it over to the 85 hp, mounted it all up and was rushing in poor light when I attached the electrical and forgot how it was supposed to go. Which seems to have caused a fatal error.
              #38989
                quote mgsolakis:
                Again, I am confused. Does your tilt motor have two or three leads? You will make a mess, damage stuff if you try to adapt the two relay trim/tilt junction box/harness to the three wire tilt motor.
                PS You can email me the pictures if you like, I will post them: Don
                • This reply was modified 7 years, 12 months ago by Don.
                • This reply was modified 6 years, 11 months ago by CHUCK.
                #38995
                mgsolakis
                  I’ll go out and take some pictures and send them along Don. I know this is a bit confusing. Like I said the trim and tilt worked perfect for a year on the other motor. So I know it was right but I hooked it up wrong this time.
                  #38998
                    Yes,
                    E-mail to Don the photos as he has the drawings. Two relays is all you need to reverse the motor. One motor has three leads, the first is the common return to the battery, The second & third wires run the motor clockwise then counter clockwise. Then the next relay energizes the second function like up & down. You wouldn’t hurt the actual pumps as they are made to reverse. Next the hydraulic cylinders have two ways of building them. They can be single or double acting cylinders. The single acting cylinder has one port for pressure which pumps fluid to raise the motor. Going down it uses the weight of the motor & no fluid is pumped. It operates by the weight of the motor & opens a solenoid valve that opens & returns the compressed fluid back to the reservoir. The double acting cylinder opens two ports on the cylinder & one side of the piston gets filled by the pump & the other side of the piston gets evacuated back to the reservoir. this makes the cylinder change directions. Reverse that & the cylinder changes direction. There is more to it but that is the basic operation. Now if you connected the up & down wires to the battery thru the solenoid it would not be good on the relay or the pump motor. You may of caused a dead head too where the pump is running trying to move fluid & no ports were opened.
                    Hope this helps & THANK YOU DON for your help!!
                    Don would you send me a drawing so I can learn too?
                    God bless you! Jeff.50@cox.net.
                    #38999
                    mgsolakis
                      Ok so I sent Don some pics of what I’ve got and I’m sure he will post them when he get a chance. In order to check things further I cut the two wires coming from the trim motor to isolate them an touched them to a battery and it worked fine. So perhaps I burnt out the relays? I bought some 12Vdc 40 amp relays but they are not official replacements. I also changed the switch just in case.
                      #39000
                        I’m so sorry about the relays. There are different relays too. Is the relay normally closed or normally open with no battery power. Also they are wired to reverse the polarity on the output, not just close as in single acting. That too includes the hydraulic valving, some port normally open or closed. Then comes the third setting using the hydraulic porting where they snap closed. If it doesn’t snap closed it will become sloppy & not hold position.
