Home › Forum › Ask A Member › Evinrude 5.5 won’t start
- This topic has 54 replies, 8 voices, and was last updated 4 months ago by
JACQUES.
May 13, 2026 at 10:50 pm #318707
Hello all,
I’m a brand new outboard user. I bought a 1955 Herters Hudson Bay a couple of weeks ago and it came with a 1960 Evinrude Fisherman 5.5 hp engine. Previous owner said the engine had been recently refurbished, and indeed it looks clean and new inside and out, but I can’t get it to start. It shows no signs of ignition at all, whether I choke it fully, halfway, or not at all.
I have filled the gas tank with new gas mixed to 16 to 1 ratio, and replaced the fuel line assembly. Fuel is getting to the fuel filter, and also to the carburetor, which I think has a leak since fuel is collecting in the housing underneath it.
I tried removing a spark plug, connecting it to the spark plug cable, and holding it against the engine block while the engine was being cranked, and there was no spark.
The starting instructions on the engine cover say to open fuel cap oil vent, and open fuel valve, but I don’t know what that means or where those things are.
Other than disassembling the engine to find the source of the fuel leak, I’m not sure what to do at this point. Any help is much appreciated.
May 13, 2026 at 11:57 pm #318710first.. fix the carb fuel leak you have a great kicker with fuel pump, thermostat . when you get it going replace the gear case oil.
if it does not spit water out the back you will need to replace the impeller !! DO NOT RUN THE ENGINE without a working impeller. A new one will be required when you do get it running. A tricky task but normal…. see video and a place to get parts.
Call them to order the proper kit for a 1960 model year !
http://www.youtube.com/watch?v=EY2HrEdp5vg
refurbishing oldies is a great hobby and getting them running again is very satisfying.
one critical test to do before sepnding$100 + to properly refurbish you Fisherman…. is to do a compression test. The motor is 70 years old and can be a good runner for another 25 years ++ but if compression is to low to run properly a full rebuild will make the investmnet questionnable as there are lots of good oldies around.
The 5.5 hp 1960 is a great engine and one book for beginners is this one in kindle version
visit also this site ” Leroy’s” for lots of info on oldies and the OMC family engines ( Johnson – EVinrude )
https://www.leeroysramblings.com/
so…..that said
no spark is the reason..it won’t fire if the carb section has been taken care of ((lots of utubes on cleaning carbs)
have you measured ohms on the HV side from plug boots to engine frame … post your results…. expect 4-8 Kohms
what has been done to service the electricals (points cleaned ?? , condenser tested /replacemed , coil replacement (most are cracked)
plug wires…
download this free book if you plan fixing oldies
https://www.socalaomci.com/library/johnson_service_manual_10th_edition.pdf
http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
May 14, 2026 at 8:17 am #318751first.. fix the carb fuel leak you have a great kicker with fuel pump, thermostat . when you get it going replace the gear case oil.
plug wires…
Thank you very much. That is a huge amount of helpful information! I intend on trying to fix it myself so we’ll see how that goes. Can you explain a little more about checking the ohms? What does the HV side mean? I will also check out the service manual that you provide provided a link for.
May 14, 2026 at 8:26 am #318753Well, you mention it has no spark. Did you try both plugs to check for spark on either cylinder? It won’t run with no spark. Remove the rewind starter and you will notice an inspection cover on top of the flywheel that can be removed with a few screws. Remove the cover and have a look at the ignition coils/components inside. Pay close attention to to potting on the ignition coils. Is the potting chipped, cracked, flaked off? If so, you will need to overhaul the igntion system. If not, you can simply check the point gap and clean them without removing the flywheel. You will need to clean up/dry any fuel spilled in the lower motor cover before attempting to check for spark again.
I’m not sure what instruction book you are using for this engine. But, your engine does not have a fuel valve, or a fuel cap oil vent. Needless to say, you must repair any fuel leak issues before attempting to run the engine. Post some pictures with specific questions.
May 14, 2026 at 9:01 am #318756the ignition coil is like a common transformer one side is HIGH voltage one side has low voltages built up by magnetic induction.
the high side feeds HV to sprak the plugs. it results when points open and the collapse the store energy in the low side coil forces the coil to maintain its stored energy generated from rotating magnets. The collapsing field in the ” low side” induces the high side to build up a high voltage with nowhere to go but the spark plug to reach ground.
that HV inner coil side (secondary)….. has about 4-8 KOms of electrical wire resistance using air thin wires than can breakdown for various reasons. measuring OHMS from the boot plug to the engine frame will tell you if something impeeds voltage flow to the spark plug .
IF you read OPEN/Infinity the path is OPEN and needs to be fixed by replacing the coil, wires, boot pin etc.. see manual and utubes. see T mike videos…. one of many such videos on utube to help you out.
suggest you do some reading before tackling all these steps. visit the AOMCI westen site for great articles on the stuff (see misc articles)
testing outbaord coils T mike – Yahoo Search Results
Testing an Outboard Coil with a Multimeter using an ignition coil from the Johnson H or T
Magazine Articles | Western Reserve Chapter
May 14, 2026 at 12:33 pm #318777It needs good and strong spark to run. If the spark is weak or non existent, the usual culprits are, in no particular order, dirty or burned points, weak or leaking condensers (capacitors), deteriorated ignition coils.
May 14, 2026 at 2:02 pm #318786and cracked wires from years of bending
May 14, 2026 at 7:14 pm #318816Many thanks to everyone for all of their contributions. I am very grateful. It will be a few days before I can get around to taking another look at the engine, but I will report back as soon as I can.
May 23, 2026 at 9:31 pm #319751I had a chance to work on the engine recently, and this is what I found:
According to the Kindle book “Cheap Outboards”, cracked coils should be replaced. I think these qualify as cracked. There is debris in multiple places. Even though the previous owner said the engine had been tuned up, I’m thinking since I’ve got the flywheel off I might as well replace the plugs, points, and condensers too. Can anyone provide a link to a source for these parts? I don’t know any part numbers (maybe it doesn’t matter much for these old engines?) so it would be very helpful if someone could direct me to the actual parts I need.Thanks much!
Here are a few more photos:
May 23, 2026 at 9:41 pm #319757I have no clue what the black rubber ring is. That’s not my picture and I don’t know how it ended up in my post.
