Home › Forum › Ask A Member › evinrude 4443 water pump impeller
  • #188997
    omc57
      i am working on a 1951 7.5 evinrude mod.4443 i have read in past of modifying a newer type impeller to fit my motor any info on that would be greatly appreciated thanks
      #189000
        marineengine.com shows one in stock, part # 276857. Personally, I’d call club member Brian Wilcox to see if he makes that one. He makes many other impellers, using your hub.
        Others have ground down a later model 5.5/7.5hp impeller. Good luck.
        Contact for Brian—call 810-794-7685 before 8 pm est please.Or email Baron0418@att.net. please note the b must be a capital.
        #189002
        omc57
          Thanks Frank. I’ll check all the options you gave me.
          #189003
          Randy in Tampa
            Steve wood does it, it takes the 7.5 impeller from the mid to late 50s and put it on a belt sander, make sure it has the brass hub and make sure you keep checking it periodically not to take too much off 🤔
            Rotary valve Johnson’s Rule!
            #189007
            Dale
              Yes the 5 1/2 impeller will work it needs to be sanded down a little and the ID needs to be bored out a little. The sanding goes easier than I thought it would if you have a belt sander. Take a little of each side and check it often in the housing. They pump like crazy. Mine shoots the water out about 20 inches behind the motor.
              dale
              MVI_1582
              #189035
                This is what I was trying to post
                1950-Evinrude-FleetwinPg.06w
                Garry in Michigan
                #189038
                  1950-Evinrude-FleetwinPg.06w-1
                  Garry in Michigan
                  #189041
                    1950-Evinrude-FleetwinPg.06w-2
                    Garry in Michigan
                    #189044
                      1950-Evinrude-FleetwinPg.06w-3
                      Garry in Michigan
                      #189047
                      omc57
                        thanks to everyone for all the great information,i’ll try sanding down a 5.5-7.5 impeller.i’ll let everybody know how it turned out.
