Home › Forum › Ask A Member › Evinrude 4423, water pump
- This topic has 12 replies, 4 voices, and was last updated 2 months, 3 weeks ago by
davidk.
August 3, 2026 at 1:03 pm #325627August 3, 2026 at 1:46 pm #325635August 3, 2026 at 1:51 pm #325638
Evinrude 4423-4424 Parts Manual – not that big, was thinking of the owners manual, will try that next.
1947-1951-Evinrude-3.3HP-Parts-Manual
August 3, 2026 at 1:56 pm #325640Evinrude 4423-4424 Owner’s Manual
August 3, 2026 at 3:27 pm #325644Thanks Steve! I had the parts manual but not the owner’s manual. : )
In the parts diagram, it shows a “Deflector and plate assembly.” Seems to be one piece. I tried searching for that part number to no avail. Let’s see what more info emerges.
August 3, 2026 at 7:37 pm #325648Looking at your pictures, I would have to say that that top plate looks like it was attached to the lower housing. I don’t know if those are rivets going through the lower housing that are removable and are replaceable or if it was cast studs that stuck up and once the plate was put over it, the studs were peed down like a rivet head to hold the plate down. Once the impeller is pushing against the plate and rotating, you do not want the plate to spin. If it were to spin in the housing, it would wear out in no time. Just my thoughts about it.
August 3, 2026 at 8:29 pm #325651I think you’re right, Gary. Thanks for your observations.
August 7, 2026 at 8:20 pm #325883David, I am also restoring a 4423. The two parts pictured are indeed supposed to be riveted together forming a space between the two. This is a two stage centrifugal pump. The lower impeller output flow goes between these pieces, directing flow to the inner diameter of the upper impeller (your first picture). FYI, I’m manufacturing replacement impellers and currently in the testing phase. Once reliability and durability are proven, I’ll make them available to 4423 owners.
August 9, 2026 at 1:27 pm #325995Here’s a picture of the 2-stage pump water flow path.
August 9, 2026 at 1:30 pm #325997Now available… 4423 impellers. Designed, manufactured, and tested in USA. Two materials available: HiPerf and OEM type.
