Home › Forum › Ask A Member › Evinrude 4265 Coil
  • #293297
    Greg Gregory
      I’ve got an old Evinrude 4265, that belonged to my late wife’s grandfather that I’m trying to get running for my stepdaughter and I’m in need of a coil (see pictures),  Any suggestions on where I might find one or if there is a suitable /compatible one I can replace it with?  Any help would be appreciated!
      #293301
        There may be nothing wrong with the coil. How are you testing it? Tubs
        #293302
        Greg Gregory
          Thanks for your response!  The leads on the coil were brittle and not connected.  If you look closely at the second picture you can see where new leads were solder and connected and still no spark, which to me says “bad coil”.
          #293303
            If you cant find an original replacement, with some modification you can use one of these. Its a 2 spark coil so you will have to ground the lead you don’t use. This 2 lead coil is actually a plus as it moves the spark plug wire away from the crankshaft.  https://www.ebay.com/itm/232218550107
            #293305
            Greg Gregory
              Awesome!  I will give it a try and thank you.  I’ll let you know if it works.
              #293306
                wires don’t look good I agree but did you measure the coil resistance ?      condenser could be toast…      contact surfaces bad and needs a good cleaning has suggested
