Home › Forum › Ask A Member › Evinrude 35 hp will not go into gear.
- This topic has 6 replies, 5 voices, and was last updated 10 years, 3 months ago by
mgsolakis.
August 4, 2016 at 6:13 pm #4921
This is a late 50s 35 hp Evinrude model number 25532 5085. This issue is that the motor will not go into gear. The shifter moves but the motor won’t go into drive. I posted about this a while ago and people suggested removing the powerhead. I have removed the head, I had one stripped screw that gave m about a weeks trouble but I finally got it. What would be the next step?
August 4, 2016 at 7:21 pm #41594Did you look to see if the shift rod is moving up and down (behind the oval plate about half way down the shaft)? If it isn’t moving up and down, yes the next step is to access the upper end of it by removing the powerhead (NOT the cylinder head).
August 4, 2016 at 8:41 pm #41595Yep, that is my guess too. It either came apart at the shift rod coupler or at the bell crank (which is directly under the powerhead)
August 4, 2016 at 9:49 pm #41599About half way down the shifter?
August 4, 2016 at 10:38 pm #41602No Remove the ENGINE from the outboard to expose the shift linkage for trouble shooting.
ABOUT 50% down the outboard exhaust housing look for an access plate held on by two screws.
REmove those two screws & remove the plate to look at linkage coupling missing a securing screw or two
ORDER a new head gasket & replace the head. 💡August 5, 2016 at 2:35 am #41616So the powerhead is still on the motor? You removed the cylinder head? You need to drop the lower unit: un-do the bottom bolt on the shift linkage inside the door on the midsection, then un-bolt the lower unit and hopefully it will drop down with just a little help. The driveshaft sticks up about 24" or so. Then you can manually shift the L/U and see if that’s the problem. Turn the driveshaft clockwise as you move the shiftshaft up or down and check the propshaft for being in gear or neutral.
August 6, 2016 at 9:27 pm #41680The powerhead is off an it is clear to see that the shift rod an what connects it to the shifter has come apart and dropped into the bottom of the motor. I replaced the pin with one from my parts motor. Thanks for the help. Just a note to help others after opening two of these up, and seeing that the bit of wire that keeps the pin on was so rusty and worn I would put this job down as general everyone should do upon picking an old one of these motor up. If I had chosen to run the other motor it would not have been long before that one broke as well.
