Home › Forum › Ask A Member › evinrude 3,3hp 4423 lower unit
  • #285427
    Hiawatha
      are these the only places that attaches lower unit to power unit?  side bolt, dowel pin and rear screw? also any idea where to get the dowel?
      thanks dave
      #285431
        4423_L.U-1
        Hiawatha
          thanks, you wouldn’t happen to know the specs on the drive shaft screw? 200709 thanks
          #285443
            See if a 1/4″ x 20 tpi threads in the hole……it’s the most likely.
