Home › Forum › Ask A Member › evinrude 3 hp
- This topic has 8 replies, 8 voices, and was last updated 11 years, 2 months ago by
Tubs.
September 5, 2015 at 9:20 pm #2456
After careful carb cleaning, my nice evinrude lighttwin from late 60’s or early 70’s starts easily and idles smoothly. But on a small light boat, it won’t speed up like it does in my test tank, except as it’s running out of gas after I’ve closed the fuel shutoff valve. What can I do to make it run more strongly?
Dave H
September 5, 2015 at 9:23 pm #23294Have you adjusted the carb ?What model is it ?
September 6, 2015 at 12:48 pm #23327If it’s a 3hp, it’s 1968 or older. Does it have an adjustable high speed needle or just the adjustable slow speed? If it has an adjustable high speed, that needs to be adjusted on the lake at WOT. Start out with the needle open about 3/4 turn, and then adjust for maximum speed/rpms.
September 6, 2015 at 12:54 pm #23328Also, make sure it is running on both cylinders. These motors will idle quite well on only one cylinder, but will not have any power when throttle is advanced.
September 6, 2015 at 12:54 pm #23329Engines tend to rev up more in the test tank due to turbulent water/ventilation, so you may not really have a problem at all. But surely take the time to adjust the high speed needle while running on the boat, unless it has a fixed high speed jet.
September 7, 2015 at 4:21 pm #23410It’s got both low and high speed adjustment knobs. Adjusting the high speed knob doesn’t have any effect. Coils tested ok this summer. Will put spark plug lights on it to check whether both cylinders are firing under load.
Dave H
September 7, 2015 at 7:12 pm #23425If adjusting the high speed needle has no effect, the gasket may be missing on the main nozzle. But more likely is it is just open way too far. It will run rich till you get it somewhere close to optimal setting, then it will make a difference as you fine tune it. It closed down too far, it will cut the gas off and it won’t run. You obviously haven’t gotten it that far leaned out yet.
September 7, 2015 at 8:46 pm #23436If it acts like it is running out of gas, maybe it is running out of gas!
The small fuel line, shutoff tap and the filter screen in the tank all tend to get dirty and plug up over the years. If you undo the fuel line at the carb and turn the gas on, it should flow quite freely. Don’t forget to open the air vent on the tanks filler cap! If it doesn’t flow freely, a thorough cleaning of the fuel system is required.
September 8, 2015 at 1:46 pm #23473quote FrankR:If adjusting the high speed needle has no effect, the gasket may be missing on the main nozzle. But more likely is it is just open way too far. It will run rich till you get it somewhere close to optimal setting, then it will make a difference as you fine tune it. It closed down too far, it will cut the gas off and it won’t run. You obviously haven’t gotten it that far leaned out yet.
