Home › Forum › Ask A Member › Evinrude 25hp Big Twin Model 25018 “The Evil One”
- This topic has 41 replies, 10 voices, and was last updated 4 years, 11 months ago by
Shamus.
August 27, 2021 at 12:53 pm #245570
Hello all,
I bought a 1955 Big Twin 25 hp to match an electric start with the ’54 Dunphy Dolphin I am “restoring.” I have parts lists for Models 25920 and 25921 but not for the 25018, which I have learned from this forum and another one was beset by the lower seal issue. In my pursuit of setting this motor up for electric start, I have seen wiring harness diagrams for the later models, which refer to a mercury switch and choke solenoid, as well as a choke switch. Looking at the motor without pulling off parts yet, I can’t see any provision for a mercury switch (but I suppose I can add one) and a choke solenoid. The only wiring I can see are the two heavy duty cables leading from the starter motor to the boat. The boat itself was a “deluxe” model set up for a 6 volt dry cell battery wired to a key switch and a push button starter, but no solenoid that I can see, but also had two heavy duty cables that were just dangling and not connected to anything but terminated in the stern of the boat.Interestingly, the motor I bought has the extended gear case, which I would like to remove (because of the weight issue) but will require me to find a standard drive shaft.
So a couple of questions:
Does anyone have the parts list for the 25018 – is it at all different from the 25920/25921? (I looked on the inner sanctum but no 25018 parts list that I can see)
Does a wiring diagram for the 25018 include wiring for a choke solenoid and a choke switch?
IThanks for any responses.
August 27, 2021 at 1:17 pm #245571I believe 25018 and 20519 are manual start, short and long shaft. 25820 and 25921 are electric start, short and long shaft
25018 – 19 would not have a wiring diagram, since there is no electric start on those.
All are beset by the seal issue. Serial number is needed to determine which seal it has.
August 27, 2021 at 1:42 pm #245572As Frank said, no wiring diagram except in the parts manuals for electric start motors.
There should be a choke solenoid which mounts on the bottom of the carburetor bowl for that motor. Manual start motors did not have the correct carburetor bowl for the choke solenoid.
The choke solenoids and electric starters both started as 6v accessories, but I believe around 58 or 59 they went to 12v. 6v starters are fine with a 12v battery… 6v choke solenoids WILL fry with a 12v battery.
So use a 12v choke solenoid or 6v with the correct resistor in the wiring.
The only switch for the choke is on the dash which for that motor would have been a push button.
You said that motor has a long shaft gear case, and you want to remove it for weight issues… the long shaft kit weighs only 5lbs and the transom height of the boat is what will decide if you need a long or short shaft motor. 15″ for short shaft, 20″ for long shaft. Neither will perform right with the wrong length motor leg.
August 27, 2021 at 1:49 pm #245573Also, I believe to change that motors lower crankshaft seal from an oil slip seal to the better carbon seal, I think you have to split the block open and change a bearing to use the carbon seal.
I could be wrong but I remember that for some reason.
August 27, 2021 at 7:15 pm #245583There’s no doubt about the serial number and the fact the motor has electric start, see photos below. The serial number is 25018-10558, which puts it squarely in the defective gear seal category. It seems to have the proper clamshell cowling for an Aquasonic. I guess it’s possible that this is a “Frankenstein” motor, cobbled from parts, but I don’t see any obvious indications of that, but what do I know? (Nothing). There’s definitely no choke solenoid on the bottom of the carburetor, but I can’t get a photo of it unless I tear it down.
This reply was modified 5 years, 2 months ago by
Mumbles.
August 27, 2021 at 7:22 pm #245587The Johnson 1955 25 hp RDE-17 (electric start) came with a mercury switch
The Johnson 1955 25 hp RD-17 (manual start ) did not come with mercury switch
So far all the RD-17,s I have worked on – I split the block to install a carbon seal
I do not know what resistor to use to turn a 6 volt choke solenoid into a 12 volt choke solenoid
I will be out of town till Sept 5th
If you would like to talk on phone when I come back-look me up in the directory
Everything I have learned about these 25 hp s . I learned from these message boards-thank you Frank
Al Klebek1 user thanked author for this post.
August 27, 2021 at 7:48 pm #245588That motor shows signs of being seriously overheated at some point in its life. The whole powerhead should be the nice Evinrude blue but the head looks brown which is a result of overheating.
Check compression and shine a light into the spark plug holes to look for any internal damage.
Check the powerhead just behind the back screw for the recoil assembly, theres a little silver plug that has serial and model number stamped into it, if that matches the ID tag then your motor is not Frankensteined.
August 27, 2021 at 8:06 pm #245589Manual start and electric start motors look the same except for the presence of starter, choke, mercury switch, wires, etc on the electrics. And of course the decals.
August 27, 2021 at 8:09 pm #245590Thanks for that info. That little silver plug has the same serial number. The compression check done by the seller showed about 100 on each cylinder, if I recall. When did Aquasonics start being available with electric? So I still have the same problem – This model (25018) is not supposed to have electric start but it does.
August 27, 2021 at 9:01 pm #245597stuck reed valves ????????
