Home › Forum › Ask A Member › Evinrude 18 HP Fastwin won’t rev high under load
- This topic has 16 replies, 7 voices, and was last updated 6 years, 3 months ago by
JerseyBoater.
July 9, 2020 at 12:10 am #208094
Hi all,
I’ve been fighting with this thing for weeks now, having adjusted just about everything I can and replaced several parts in the process. The only thing I haven’t touched is any of the ignition under the flywheel.The engine idles great, and in the tank appears to do everything it should – I’ve had the tach on it and it revs up well over 5K.
When I get in the boat on the water (14 foot aluminum Starcraft), the engine seems to die under load. The boat tops out at about 6 kts. and the engine obviously is losing something somewhere.
I’ve been going through my manual trying to eliminate variables – one of them is clogged exhaust or exhaust getting into carburetor. How do I check this, and also what other ideas does anyone have? I have a tune up kit ready for it but I’ve been reticent to pull the flywheel for fear I’ll screw something up worse 🙂
Thanks all
July 9, 2020 at 12:43 am #208095You absolutely need to pull that flywheel and see what you have. ALL of those motors need new coils unless they have already been replaced. Not to fear, but use a proper flywheel puller and you Must use a torque wrench to reinstall it.
July 9, 2020 at 5:30 am #208097Yes, and please don’t rev it to five grand in the test tank, especially if you mean in neutral. Revving an engine high in neutral doesn’t prove ANYTHING about it’s running condition.
This reply was modified 6 years, 4 months ago by
billw.
July 9, 2020 at 7:16 am #208101Depending on the year, your engine may have an inspection cover on top of the flywheel that will allow a quick look at the coils without having to pull the flywheel…If the coil cases are cracked/broken, we are on the right track… Simply remove the rewind starter… An older engine will have a little inspection cover on top of the flywheel that is removed with four screws…
July 9, 2020 at 9:05 am #208107Definitely need to pull the flywheel. Those coils tend to be bad. Also change the points and condenser while youre at it. I’ve had points get burned up and when they do it makes you think you have a fuel problem. I’ve almost never had fuel problems. They always tend to be ignition issues.
July 9, 2020 at 6:13 pm #208195Thanks for all the replies folks. When I said revving to 5 grand it was in gear in a tank and for about half a second.
Anyhow, I will try to pull the flywheel off this evening and see what things look like. I actually already have most of the parts onhand. Unfortunately I have no peep window to see.
Will update as soon as I can, thanks again.
July 9, 2020 at 8:29 pm #208207UPDATE:
I pulled the flywheel and replaced the coils and condensers. Put it back together and the throttle arm will not turn to advance the throttle. It won’t start obviously, came close and coughed once but that was it then I realized the throttle wouldn’t advance.
What did I screw up? The flywheel was torqued correctly and the key was lined up. Not sure what would cause the throttle to be “stuck”
Thanks.
JerseyBoater.
July 9, 2020 at 8:35 pm #208209are the coils hitting the flywheel?????????
July 9, 2020 at 8:47 pm #208211I suppose it’s possible, I don’t have a ring tool or anything. But would that prevent the throttle from advancing? I don’t know, I’m asking.
July 9, 2020 at 9:14 pm #208213 -
