Home › Forum › Ask A Member › Evinrude 10? 15?
- This topic has 10 replies, 9 voices, and was last updated 10 years, 1 month ago by
EUGENE NEKOWITSCH.
August 30, 2016 at 9:20 pm #5114
I picked up an Evinrude that has a "custom" paint job. It looks like a 1953 or 1954 15 horse. The motor mount has been changed to a QD-10 mount so that model and serial number info. doesn’t help much. The Exhaust Cover does have a number from the casting and is 203252. The motor shroud has a number 203264. This motor has a label indicating it was supplied by OMC in Canada.
I was wondering if anyone could confirm the model and year from the part numbers above and the photos. Sorry about the orientation.
Also wondering about a good way to remove that awesome paintbrush finish.
August 30, 2016 at 9:27 pm #42970I agree, looks to be a 53/54 Evinrude Fastwin 15hp….
August 31, 2016 at 12:10 am #42981Another vote for the ’53/’54 Evinrude Fastwin 15hp. I have a ’54 SuperFastwin myself and I’d say this is a spittin’ image with ‘custom’ paint.
-BenOldJohnnyRude on YouTube
August 31, 2016 at 5:15 pm #43053
Absolutely Super Fastwin! The decals on the ’53 were a sort of blue gray, while the decals on the ’54 were black. . . . 🙂
September 1, 2016 at 1:17 am #43103Look inside on the engine block for a shiny silver welch plug (looks like a frost plug the size of a quarter). This will have the model and serial number.
September 1, 2016 at 10:09 am #43122Evinrude 10 did not come to the market, till 1956. Anything earlier, was a green Johnson QD. And yes, that is a Super Fastwin 15. 53 and 54 was called the "Super Fastwin" because they were a vast improvement over the previous 14hp Fastwin. 1955, the Super was dropped from the model name. 1957, they were bumped up to 18hp and vastly improved again.
September 21, 2016 at 12:29 am #44430The 1954 15 Evinrude I have has a weak throttle linkage. The horizontal to vertical gear that holds the vertical linkage to the magneto connections is damaged. There is a great deal of wear on the slot. This damaged part appears to be part of the midsection. I have an extra midsection from a few years later – probably 1956 to 1958. Is there any chance that the 1954 powerhead will fit onto a 1956 or 1957 midsection AND have the 1954 gearcase bolt up to that newer model midsection.
Seems like a long shot to me, but OMC was pretty good at interchangeability as designs advanced model to model. Maybe I should wait for a 1954 parts motor at a future swap.
The parts catalogues I have don’t cover back to 1954, and I don’t seem to be able to find any exploded view parts diagrams to check out myself.
September 21, 2016 at 1:31 am #44437The ’54 15 has a different midsection than the ’56-’58. I believe the change actually took place in ’55 but I could be mistaken. The ’54 midsection has the drive shaft completely separated from the exhaust where it mates to the powerhead. It takes 2 separate base gaskets of different thickness even. The later midsection is not divided like that. The throttle linkage parts, however, I believe are the same. Without seeing a picture, I’m not certain of where the wear / damage really is. The gears are both separate pieces though.
September 21, 2016 at 2:22 am #44440Another vote for 53-54 Super Fastwin.
September 21, 2016 at 2:53 am #44444Sorry, No welsh plug on this model. I agree Evinrude 54, 53 15hp. None of them had a welsh plug. Great runners though at 67 pounds. I would never sell mine or my 58 Johnson 18 electric start. Great motors too!
