Home › Forum › Ask A Member › Eska Experts
  • #57184
    slim60
      Another thing I don’t about them is the flaky paint Tecumseh used on the engine and carb.
      #58420
      Ron Devries
        The Eska is running again, for such a crude motor it actually runs quite well. Going to take it out to the lake and see how it pushes the Alumacraft A. I have an Evinrude Mate to get me home if the Eska fails…..
        #58429
        amuller
          Tecumseh went through a perverted period of using diaphragm carbs on all sorts of engines 2 and 4 cycle. My opinion is that I would not likely bother with any such engine unless I had a float carb to put on it, or it was something really special. The only good thing to say about it is that the motor likely has very low hours due to people giving up on starting it.
          The water tube is better than the pump as the pump impeller may not be readily available. I suspect Eska went to the pumps when they started to use neutral clutches, as there would be no flow in neutral with the prop still.
