Home › Forum › Ask A Member › Epoxy repair inside a carb
- This topic has 9 replies, 7 voices, and was last updated 10 years, 11 months ago by
Steve D.
November 17, 2015 at 9:56 pm #3002
I’m usually a little leery of epoxy repairs on carbs. But I was wondering what your opinions were on this. The carb had a lot of corrosion inside similar to picture #1. To the point that it weakened the top part of the post for the hinge pin, and it crumbled away leaving no hole for the pin itself. So I assembled the pin in the float arm and laid it in where it’s supposed to go and epoxied the top, picture #2.
I used 5/1 Marine-Tex, not the 50/50 quick-set version. Has anyone one else used Marine-Tex for a repair submerged in gas? I put a little piece of cured epoxy in a container of gas to see what happens but not sure of the long term results. I think we talked about this before concerning gas tanks and the results/opinions varied.
I’d hate to have to scrap the carb since this is all that’s wrong with it, but I don’t want to get stuck either.
imagehost
photos uploadNovember 17, 2015 at 10:15 pm #27252What’s the casting part number, I have a couple of 25 hp carbs laying around.
November 17, 2015 at 10:26 pm #27253Thanks for that offer Ken, I appreciate it. It’s from a ’60 Evinrude 18 horse and I do have a back-up for it but I’m hoping to be able to keep this one in service if I can.
November 18, 2015 at 12:23 am #27265I had the same thing happen on a saltwater used 1955 Fleetwin carb. I took the easy way out, scrapped the upper carb section and retrofit one from a parts carb that I had on hand.
That carb looks great and so does the repair. Nice job.
Improvise-Adapt-Overcome
November 18, 2015 at 2:18 am #27272Steve,
I think it would be interesting to run it and use it as a "test" case to see how this type or repair holds up over time.
November 18, 2015 at 2:42 am #27274Keep the chunk of epoxy in the fuel in a jar on your work bench. If it ever breaks down, time to swap the carb out!
November 18, 2015 at 3:33 am #27279If i didn’t have another choice, i would use a strip of brass as a replacement post. Fastening it with a #4×40 screw and pin.
November 18, 2015 at 3:45 am #27280Thanks for the comments guys. I think I may just use it as a "test" case and keep my eye on the chunk I have in the gas. If the canary drops from its perch, I know it’s time to get out of the mine. š®
November 19, 2015 at 12:23 am #27340Steve, do you have any way to make an aluminum replica that can
be soldered on with the aluminum welding rod and MAPP torch ?
might be a worth while project if you have an old carb that you can sacrifice
for the practicing.November 21, 2015 at 3:09 pm #27463Yeah, if this doesn’t work I’ll have to try something else…or just scrap it. Thanks Johnny.
