Home › Forum › Ask A Member › Enough power?
  • #7338
    mikeg
      I have a 16′ tiller steer fishing boat, power is 1963 28hp Evinrude.
      New carb kit, Ignition, good compression.
      Boat is 420lbs, battery in rear, fuel tanks in front. With me (200lbs) this boat
      has a hard time getting up on plane, top speed is 17mph.
      I’ve tried a couple different props and tilt settings. Is this all I should expect?
      I do have a 35hp, but would need to convert to long shaft.
      What do you think.
      Thanks, Mike ,Buffalo,NY
      #59727
      RICHARD A. WHITE
        Have you looked at your USCG tag for rated hp of that particular boat?
        should be back on the inside of the transom.
        classicomctools@gmail.com
        #59731
        chinewalker
          What are you running for a prop? Boat is fairly light. Those old 28s are good pullers. Might help if you drop down a notch in prop pitch to bring the RPM up. Akin to dropping down a gear when going uphill while towing a trailer.
          #59733
          hmai
            I have a 25 hp bigtwin with a similar boat. 16ft utility. I am a very large guy and it doesn’t matter what i have in the back of the boat it will do high 20’s almost 30. It will plane the 16ft utility at 2/3’rds throttle. Have you made sure it is throttling up all the way? Long shaft on short shaft transom etc.
            #59742
              After a run are both plugs dry? My first outing with my first outboard was only firing on one cylinder. Testing that the spark jumps 20 thousandths on the plug in open air wasn’t enough: in open air you need to test with a quarter inch gap, and the spark should be blue and have an audible snap.
              #59743
              mikeg
                Boat is rated for up to 40hp, long shaft motor on long shaft transom.
                It has never sounded like it’s "winding up". What should I look for to increase RPM,
                besides prop?
                #59757
                retiredoz
                  What are the specs on the prop you’re running now ?
                  #59758
                  hmai
                    This is my 7.5hp, but same concept. Under the flywheel/magplate you will see a roller riding on a 1/2 moon. I.believe u want it to ride as far left when fully advanced without going off the plate. On the start position it should just barely touch on the plate.
                    Is the motor original to the boat? You may have lost a 8th of a inch off the prop without knowing it. A prop shop should be able to tell you and recommend the proper pitch for tour boat.
                    Both plugs firing and looking ok? You can get a bad condenser.
                    SCOTT BOGUE
                      Definitely does not sound like you are getting all 28 hp. I have an 18 foot utility, 460 lbs empty, that would do 20.3 with a 15 hp Yamaha with one aboard.
                      Lots of good advice here – check to be sure that at wide open throttle, the throttle butterfly is horizontal. The throttle and spark linkages could be out of whack. Also, be sure the neutral/reverse throttle stop is properly adjusted.
                      Angle, transom height, propeller conditon (not diam and pitch) can all have an effect, but I think much more is involved here.
                      #59760
                      David Stanton
                        Going to a short shaft motor for your short shaft transom should get you at least another 5 MPH – you are essentially dragging a 5 inch club through the water. I’ve seen blocking the motor up the thickness of two paint stir sticks (about 1/4 inch) give a 35 HP motor another 2 MPH on a lightweight 14′ aluminum runabout. Gas mileage will increase too.
