Home › Forum › Ask A Member › ENGINE STAND ANGLE
  • #6120
      What is the correct angle for an engine stand?
      WAYNE
        It varies. I shoot for about 10 degrees.
        Wayne
        Upper Canada Chapter
        uccaomci.com
        #51141
        thumper
          I somehow remember it being 14 degrees from reading my old Scott literature. 10 degrees would be pretty close!
          #51142
            12 degrees is supposed to be standard.
            But few follow that standard. . . 😆
            #51143
            thumper
              I guess we’ll split the difference Wayne 😉
              #51146
                These ones were kicked out to roughly 12 degrees to mimic a transom. That’s about 2 1/2 and 12 on a framing square.
                green-thumbs
                  Mercury manual assumes 12 degree transom angle in set up guide.
                  #51154
                  49hiawatha
                    Okay what is the mechanical/technical advantage of having the stands at that 10-12 degree angle? I do not run my motors off the stands. My boat transom is perpendicular. I have angle adjustments on my motors. I can adjust angles off the perpendicular. Educate me . Please.
                    #51155
                    fisherman6
                      My thought is that it puts the center of gravity more directly over the base of the stand since it makes the motor hang closer to vertical. That would make it more stable on the stand. That said, none of my stands are built on an angle. I have not found a need to do so yet.
                      -Ben
                      OldJohnnyRude on YouTube
                      #51157
                        quote 49Hiawatha:
                        When you tighten up the clamps, the motor is close to being vertical. This makes it easier to work on and looks better than having the motor kicked out on an angle. It also makes it easier to run the larger motors with their lower end dipped in a tub of water. On my storage racks for donor motors, the cross piece is straight as most of them are missing the clamps anyway.
