Home › Forum › Ask A Member › Elto Ruddertwin Grease
  • #6098
    slim60
      What is this pin for on my lower unit? Could it be an indicater for the grease level?
        Nope.
        It locks the adjustable front prop shaft
        bushing after setting the end play.
        You can see the other end sticking down
        looking at the front of the gear case.
        #51004
        slim60
          Thanks Tubs. OK, I see it in the parts list. I gave it 24 pumps with the grease gun and stopped. Did’nt want to blow a seal. Should be enough?
          #51012
            Wheele bearing grease is not what "Grease" means when referring
            to these early outboards.
            If your talking about using Corn Head grease that’s a good choice.
