Home › Forum › Ask A Member › ELTO rudder twin timer help
  • #258224
    JOSEPH BRINCAT
      I have just been asked by a fellow for help in getting his father’s old ELTO rudder twin running. I don’t have experience with the Attwood Kent timers, but I know to use extreme caution. I’m going through old “Outboarders” looking for tech articles on the subject. Any leads to which issues? or info here on the forum… so far no “search” is helping.
      #258226
        Here is a slide show I did on the timer some time ago.
        https://youtu.be/zLS6IglCy9k
        #258228
        JOSEPH BRINCAT
          Thanks Tubs, that is the tutorial that I remember… and as is usual from your “studio” , an award winning production
          #258282
          JOSEPH BRINCAT
            Tubs, thanks again… I got a look at the Elto Rudder Twin (model J) today. The timer is in need of help. The bushing is crumbled, and the strap ( link) is missing.
            Did you make the brass bushing from scratch?  How about a new link?  I haven’t called Art DeKalb yet to see if he has castings?
            Interesting story with this motor, belongs to a fellow that I just met at a restaurant today, turns out he is a neighbor. The motor was his fathers, been in safe storage for 40 years. Very much wants to get it running , use it and have fun with the grandkids. This is one of the few motors, with which I’m unfamiliar, Fortunately there are other friends that are. The motor looks like it’s in good shape, the coil is good… ran the last time that “dad” ran it!
            All in all , I think that we will gain a new and enthusiastic club member.
            #258294
              I know Art has made them in the past. Also
              Doug Penn has offered them but I believe he
              gets them from Art. You may get a response
              from someone reading this thread as I have
              gotten them from different people who have made
              them over the years. I recently gave someone the
              prints to make their own but I don’t know if they
              have any interest in making more. Art may
              reproduce the strap as well.
              #258316
              JOSEPH BRINCAT
                Thanks Tubs,  I was about to start making them myself, patterned off the crumbled bushing. If you have the prints for the link and bushing, much appreciate it if you can send.
                Here or to my e-mail … I can send a PM
                Thanks
                Jo e
                #258330
                  Joe – Sent you a PM.
                  #258337
                  JOSEPH BRINCAT
                    Tubs, got it … thanks, came thru “loud and clear”. Your handy work I suspect, super
                    Joe
                    #258421
                      The only Ruddertwin I have right now is a C.
                      Took a while to dig it out. Trying to get you the
                      center to center distance. The line at 2″ on the
                      ruler is deceiving. Looking at the spacing of
                      the outer lines on the paper seem to indicate the
                      center to center distance is closer to 1 – 15/16″.
                      You can get the hole dia. from your flywheel
                      and timer. The red line indicates where a hole
                      need to be drilled. Oil that exits the upper
                      crankshaft bearing travels through this hole
                      to lubricate the timer.
                      #258422
                      JOSEPH BRINCAT
                        Thanks Tubs,  when you have time and a caliper, please take three measurements.
                        • inside diameter of each bore
                        • the distance between each hole (edge to edge)
                        • From these three measures, I can calculate the true ctr to ctr distance
                        Thanks ,
                        Joe
