Home › Forum › Ask A Member › Elto Rudder twin advise needed please.
- This topic has 11 replies, 6 voices, and was last updated 9 years, 2 months ago by
jimross.
August 9, 2017 at 3:00 am #7850August 9, 2017 at 9:27 am #62706
Yes they can be rebuilt. Lots of threads on that here on the forum. Check the coil, if it fails, you can use a zephyr coil.
Most of the work is cleaning out the old material!
Lots of experts on this forum on this
August 9, 2017 at 9:44 am #62707Yes they can be repaired as stated above.
It has been my experience that the common failure mode with them is the internal condenser (capacitor) goes bad.
If the coil secondary is still good then the capacitor and wiring can be repaired and the coil will throw hot spark again.August 9, 2017 at 1:00 pm #62715Here is one option for the coil.
https://www.youtube.com/watch?v=e2vxDqF_OEUHave a couple others floating around in my head
but haven’t gotten around to them yet.This will give you the basics of the timer.
https://www.youtube.com/watch?v=zLS6IglCy9kPoints are no longer being made and if you
screw them up replacing them can be difficult
and expensive. If no one has been in there ahead
of you just some cleaning is likely all it will need.
August 9, 2017 at 1:51 pm #62718I followed Tub’s advice and rebuilt a Ruddertwin coil with a Zephyr coil. It seemed to work well. The entire time I was doing it I couldn’t help wondering if there was a more modern coil that would be suitable. I haven’t looked into it, but it sure would be nice to pick up a brand new coil instead of using 70 year old replacements.
Wayne
August 9, 2017 at 2:12 pm #62720This is fantastic….thank you.
August 10, 2017 at 2:24 pm #62779Once stuff was made to last. Now it is
purposely made not to last too long.
For the most part these 90 year old
Super Elto coils are still good. Its just
the wire that has failed. A 70 year old
Zephyr coil that is still working as it
should could easily out last most of
the stuff that comes from China and
the like today.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
August 10, 2017 at 4:05 pm #62789In regard to replacing points: go to Atwater-Kent ignition parts an you will find the points for Ruddertwin, Speedster and ’28-30 Quad under the brand name of 2 dozen teens thru 20’s Auto’s using the same AK ign parts. At present there is a set for $20.00, look at the picture. Jim Ross
August 10, 2017 at 5:41 pm #62801quote Tubs:Once stuff was made to last. Now it is
the like today.That’s true, but I don’t want to buy a Zephyr every time I want to fix an ELTO 🙂
Wayne
August 10, 2017 at 7:57 pm #62808quote jimross:In regard to replacing points: go to Atwater-Kent ignition parts an you will find the points for Ruddertwin, Speedster and ’28-30 Quad under the brand name of 2 dozen teens thru 20’s Auto’s using the same AK ign parts. At present there is a set for $20.00, look at the picture. Jim RossIs this a website you are referring to? Can you post a link?
