Home › Forum › Ask A Member › Elto Pal fuel line
  • #57895
    ray-schaber
      1/4" is too big for that motor.
      Ray
      #57897
      bob-d
        Why not just shoot Doug Penn an e mail. If he doesn’t have a Pal line I’m sure he will have something in the right size you can adapt.
        #57899
          Yep – its 3/16". As he stated "no tools"
          he would need to take the line with
          him and have it cut to length. A
          freehand bend will be fine for this
          stuff. I think he’ll find that if he
          want to run 80 year old motors he
          is going to have to start investing it
          some tools but my intent is to have
          him accomplish this with only the
          7/16" wrench he needs to remove
          the line. For what Doug would have
          to charge to make it worth his while
          plus shipping would be many more
          times than it would cost to make one.
          Maybe he’s not concerned with the
          cost though.
          #57900
            quote Garry in Tampa:
            Ferrule is correct when used on tubing, referred to as grommets or eyelets when used to line holes. It uses quarter inch copper tubing. Ferrule is a adaptation of two Latin words meaning a small iron bracelet. . . 😉
            Its been awhile ago when I was watching one
            of these gear head shows and this individual
            was explaining what the correct name was
            but I cant remember. All the supply catalogs
            list them as sleeves so what ever he said it
            is nobody calls them by that name. I thought
            someone here might know. That was the
            only reason I mentioned it.
            #58067
            amuller
              An auto parts store will likely also have the 1/4 inch compression fittings and tubing. Copper tubing comes in several different wall thicknesses, as in K, L, ACR, or "utility." You can use flare fittings rather than compression type if you have a flaring tool. Flare connections, IMO, tend to be somewhat more reliable.
              #58162
              mike-stroz
                What I meant by not having any tools was that I thought it took special tools to put those (ferrules?) on the ends. I’ll look around for some copper line and parts to replace it soon, but for now, I managed to get the kink out well enough for decent flow. I actually contacted Doug Penn, but he said he didn’t have any Elto’s like this in stock.
