Home › Forum › Ask A Member › Elto Cub coil
  • #10449
    lyks2tinkr
      As usual the coil in my cub is open. I was successful in doing surgery on one in the past and we’ll see about this one.
      Is there another coil that can be adapted for use?
      #78940
        Just recently did one.
        Took longer than I expected.
        https://www.youtube.com/watch?v=71W9cPMV09A
        #78942
        bob-d
          Another option for a coil is a Disston Mercury D0-100 DO-101 Chainsaw Coil. that what I used on my Cub.
          As with Tubs coil, it involved a bit of cutting and grinding. Found mine on EBay.
          Bob D
          #78947
          lyks2tinkr
            Thanks for your efforts and posting.
            They are small coils indeed.
            Was thinking of trying one of those single output "miltary standard" coils. Will do some measurements
            #79070
            lyks2tinkr
              Well, exploratory coil surgery went ok.
              I was able to find the broken end eventually and now have good secondary resistance.
              I have a new lug made that will anchor better in the coil. The original lugs were way to small and poorly anchored and it didn’t take much to snap the extremely fine secondary wire.
              I’ll post some pictures when I put it all back together.
              #79491
              lyks2tinkr
                Finally was able to put it all back together.
                I made a bigger T shape lug and anchored it well.
                Used dual wall heat shrink as the outside insulation.
                Patience is the key when attempting to do this. The wire is so fine it breaks really easy.
                Will put the mag back together and check for spark.
                lyks2tinkr
                  Was the original spark plug wire on the Cubs cloth covered or just rubber?
                  #79503
                    #79513
                    lyks2tinkr
                      Thanks Tubbs. I assembled the mag today and roughly set the points. Got a nice decent spark again.
