Home › Forum › Ask A Member › Elto Cub carb needle gland packing
  • #2692
    bob-d
      Hi all, what can be used as a substitute for part # 171089, the gland packing that goes around carb needle.
      When I cleaned the carb, it looked like cotton string? Did OMC use string back in the day?
      Thanks,
      Bob D
      #25051
        Here is the factory parts book …
        The needle valve packing is carried by OMC/BRP as number 0171089 – see
        http://www.marineengine.com/newparts/part_search.php?part_num=0171089&x=10&y=5
        It also may be fashioned out of heavy gasket material. Some use Teflon plumbers caulk, some use "O" rings.
        #25052
        bob-d
          Thanks Garry,
          You always have great info!!
          Looked on Marine Engine, checked their website but kinda worried about only 1 left. Last time I ordered some Mercury 6HP KD 4 gaskets from them with 2 left, it turned out the computer inventory didn’t match what was on the shelf.
          Thanks,
          Bob D
          #25289
